G-SYNC 101: External FPS Limiter HOWTO
In-game vs. External Framerate Limiters*
*As of Nvidia driver version 441.87, Nvidia has made an official framerate limiting method available in the NVCP; labeled “Max Frame Rate,” it is a CPU-level FPS limiter, and as such, is comparable to the RTSS framerate limiter in both frametime performance and added delay. The “Nvidia Inspector: 2> Frame Delay” setup detailed further below is legacy, and does not apply to the “Max Frame Rate” limiter, the setup of which is also now detailed below it.
As described in G-SYNC 101: In-game vs. External FPS Limiters, In-game framerate limiters, being at the game’s engine-level, are almost always free of additional latency, as they can regulate frames at the source. External framerate limiters, on the other hand, must intercept frames further down the rendering chain, which can result in delayed frame delivery and additional input lag; how much depends on the limiter and its implementation.
In-game framerate limiters, however, aren’t available in every game, and while they aren’t required for games where the framerate can’t meet or exceed the maximum refresh rate, if the system can sustain the framerate above the refresh rate, and a said option isn’t present, an external framerate limiter must be used with G-SYNC to prevent V-SYNC-level input lag instead.
RTSS is a CPU-level FPS limiter, and introduces up to 1 frame of delay, whereas Nvidia Inspector uses a driver-level FPS limiter, which introduces 2 or more frames of delay. See G-SYNC 101: In-game vs. External FPS Limiters for complete details, along with input latency tests comparing the two external solutions against an in-game limiter.
RivaTuner Statistic Server: <1 Frame Delay
RTSS is available standalone here, or bundled with MSI Afterburner here.
If only a framerate limiter is required, the standalone download will suffice. MSI Afterburner itself is an excellent overclocking tool that can be used in conjunction with RTSS to inject an in-game overlay with multiple customizable performance readouts.
Blur Buster's G-SYNC 101: External FPS Limiter HOWTO
RTSS can limit the framerate either globally or per profile. To add a profile, click the “Add” button in the lower left corner of the RTSS windows and navigate to the exe. To set a frame limit, click the “Framerate limit” box and input a number.
An unofficial extension of the official Nvidia Control Panel, Nvidia Inspector (download here) exposes many useful options the official control panel does not, including a driver-level framerate limiter.
Nvidia Inspector can limit the framerate either globally or per profile (more details on profile creation can be found here).
To set a frame limit, locate the “Frame Rate Limiter” dropdown in the “2 – Sync and Refresh” section, select the desired limit, and then click the “Apply Changes” button in the upper right corner of the Nvidia Inspector window.
As of Nvidia Profile Inspector version 2.1.3.6 and Nvidia driver branch R381 or later, a new “Frame Rate Limiter Mode” dropdown has been introduced with a “Limiter V2 – Force Off” option:
This option claims to reduce the limiter’s input lag; exactly by how much, and with what combination of settings, remains to be determined.
NVIDIA Control Panel: <1 Frame Delay
As of Nvidia driver version 441.87, Nvidia has made an official framerate limiting method available in the NVIDIA Control panel labeled “Max Frame Rate.”
To set a framerate limit, navigate to the “Manage 3D settings” section in the NVCP, locate the “Max Frame Rate,” entry, select “On,” set the desired limit, select “OK,” and finally select the “Apply” button after it appears in the lower right corner of the NVCP window.
3714 Comments For “G-SYNC 101”
kdog1998
Member
kdog1998
regarding low latency mode and reflex, when exactly do i turn them on or off? I use RTTS and set a fps cap to 65 in a game, my gpu hits that easily so i can maintain smooth gameplay. Do i still need to have a low latency mode enabled? would i set it to on or ultra or neither? in another game, i either exceed or sometimes sit just below my max refresh rate, do i need to use either reflex or low latency mode if available?
I have also noticed something weird when it comes to fps caps and im not sure what causes it, if its my monitor specifically or g sync. In example god of war ragnarok, i was able to hit 160 fps uncapped and when i would rotate my camera it was buttery smooth. But if i added a fps cap, even if it was 157 fps the camera panning was unsmooth and seemed excessively blurry. I tested this by going to a hard to run area, and uncapped my fps. at uncapped 120 fps camera panning was smooth , but if i placed a fps cap at 120 and panned it was wrong weird again. it only happens with a fps cap in place. ive tried it with ultra and on low latency mode and both have the issue, but i have not tried it off completely. I hope this makes sense and doesnt seem like rambling lol
brunobf
Member
brunobf
I’ve got a weird stuttering and ghosting in some games like Horizon when using FrameGen with G-Sync and V-Sync. I have a Samsung QN85A, 9800X3D, and RTX 5090. Disabling FrameGen solves the problem, but I don’t want to lose the functionality.
iLance1
Member
iLance1
I used the recommended settings, but when I turn VSync on in Silent Hill F, I get a lot of stuttering. When I turn it off, it runs fine. Does G-Sync still work or not?
Brayqzor
Member
Brayqzor
I’ve got a weird stuttering on all my games, everytime i move my mouse. I just played today without any issues and after coming back a few hours later, every game stutters rly hard when i move my mouse. i can feel it and see it on the fps indicator. i plumps to like 20 fps everytime the mouse is moving. I have this issue since day one, but only when i stream my screen on discord and it didnt bother me that way but now the issue happens even though i dont stream. again rly weird since i played a few hours ago without any issues. no update was made, as far as im aware off. I found out that Gsync is the issue. when i turn it completly off the stutters dont happen anymore, but i dont want to turn gsynch off. i use the windows and fullscreen mode. I rly need this fixed since almost every game needs mouse input. Anyone had this issue?
My System (Laptop). Ryzen 7 7435HS, RTX 4070
barry12345
Member
barry12345
Is there any explanation why my CS2 is capping at 200FPS with a 240Hz monitor?
Using Gsync + Vsync (nvcp) + reflex
With Vsync off it will uncap and I get around 300FPS so it should be able to cap at 225 like it does for everyone else?
With Vsync on the FPS is still capped at 200 even with a 225 limit set in nvcp.
barry12345
Member
barry12345
Overwatch with these settings caps at 239 instead of 225.
wpDiscuz
